STARTS THEN DIES!!!
2001 JEEP CHEROKEE
90,000 MILES • 4 CYL • 2WD • AUTOMATIC
LUCASWADE84
OK...i can crank this Jeep up, with giving it some gas...then it will stay on and idle at like 500 rpms for about 30 seconds then it dies!!! what's wrong!!!????
Dec 14, 2007 at 1:10 AM
MCQUE
  • 20 POSTS
you need to check fuel pressure before starting and while running, so you will need to find a pressure test guage and connect it to the schrader valve on the fuel rail. ...if that tests good, you may be having a problem with your Crankshaft position sensor, Throttle position sensor, or a few other things...
IAC, Camshaft sensor,...bad ground connection...
If no check engine light...probably Cranshaft sensor..
If you are handy, and have the tools, get a Service manual start with a fuel pressure check...
Dec 17, 2007 at 11:47 AM
