2001 Jeep Cherokee STARTING PROBLEM WHEN COLD
80,500 MILES • V8 • AWD • AUTOMATIC
SHANNON/ DAVE
I HAVE A JEEP GC LIMITED,, WHEN IT IS COLD IT WILL START BUT THE IDLE IS ABOUT 300 TO 400 RPMS, FOR A COUPLE OF SECONDS THEN IT GOES TO NORMAL. SOMETIMES IT DOES NOT TO START THOU.. IF I START IT WITH THE REMOTE START IT WILL START FINE.... PLEASE HELP WITH THIS PROBLEM TANK YOU MUCH DAVE..........
Jan 7, 2008 at 6:13 AM
2CARPRO JACK
  • 11,533 POSTS
by not start do you mean not crank? or turns over and wont start?
Jan 7, 2008 at 7:06 AM
SHANNON/ DAVE
IT TURNS OVER FINE BUT WHEN IT DOES START COLD IT HAS A VERY LOW IDLE..... THEN IT GOES BACK TO NORMAL.. DAVE
Jan 7, 2008 at 10:11 AM
2CARPRO JACK
  • 11,533 POSTS
Might want to try cleaning out the throttle bore with some carb spray and a rag around the butterfly.This should help stabilize the idle
Jan 7, 2008 at 11:07 PM
