2001 Jeep Cherokee Starting problem
RAYSOF
Electrical problem
2001 Jeep Cherokee Automatic
Hi!,
Sometime it happens that when I try to start the engine car doesnt start. All the display indicators go dead as if there is no battery in the car. I checked the battery it's fine still shows green. Now, when I disconnect the battery fully and connect it back again everything goes normal car starts but later after few days again I get the same problem.
Please suggest what could be the reason please advise.
Regards,
Abdul
Mar 16, 2010 at 2:41 AM
CJ MEDEVAC
  • 11,000 POSTS
See my profile. Just a thought, go to the SOLINOID and make sure all connections are clean and TIGHT.
Let me know if that was the problem !
Love, Turddog
Mar 17, 2010 at 4:33 PM
KABARSEDGE
Abdul,
I know I'm a little late to the game, but I actually incurred this same problem. For me it wasn't one issue, but many small ones. Corrosion on the solenoid and cables, bad battery terminals, and a weak battery. New brass battery terminals and a wire brush to all the connectors helped, but didn't completely solve the problem. I also upgraded from the standard 500 CCA battery to an 800 CCA battery. Once I did all of this, it seemed to clear up all my problems. My Jeep actually runs smoother now, as I think the corrosion to the engine block and body was causing a ground issue. Hope this helps. Take care.
-={KaBarsEdge}=-
Apr 23, 2010 at 1:10 PM
