2001 Jeep Cherokee Radiator Fan Motor
2001 JEEP CHEROKEE
98,000 MILES • 6 CYL • 2WD • AUTOMATIC
DOCROCKET
How do you know if the problem is the Radiator Fan Motor or a rely. Also, what are the procedures to change out both.
Mar 30, 2008 at 1:40 PM
What you need is a repair manual see below link if you wish to download it-checking the fan motor- direct power to it-don't come On when direct-motor is defective other stuffs will cause the fan not to come on-such as the fan relay/wiring problem/engine coolant temperature sensor and the computer fan relay controls-
Mar 30, 2008 at 2:15 PM
