2001 Jeep Cherokee P1762 code
107,000 MILES • 6 CYL • 4WD • AUTOMATIC
PIT495
I recently got a DTC trouble code P1762, the description Im getting for this code pertains to governor pressure sensor. Im really not sure what that means. Is there any easy fix for this?
Sep 6, 2008 at 6:10 AM
ROB2008
  • 258 POSTS
Gov. Pressure Sensor.It is located in the valve body of the transmission and requires dropping the transmission pan to replace. Sounds much more difficult than it is.Since you have to change your fluid it's a good idea to change the trans. filter .
Sep 6, 2008 at 6:33 AM
