2001 Jeep Cherokee Not Starting
CINDY CARROLL
  • 2001 JEEP CHEROKEE
  • 6 CYL
  • 4WD
  • 63,000 MILES
Side Note: Less than 1 year ago I had a new battery installed. The installer had to cut back connector wires as there was much corosion.
Currently when I turn the key I get a "tommy gun" type sound. Then after trying a couple of times I just get a click sound. Also my gas gauge had stopped working last winter and suddenly the gas light went on and the guage moved - it is not accurate - but it moved. At the same time the radio stopped working when the fan was turned on. Also the electric windows sometimes don't work.
I would like to have some idea what the problem may be before I take it anywhere to be fixed. I looked through the manual and the only part that seems applicable is the electrical power distribution center.
Any help or information is appreciated!
Friday, February 26th, 2010 AT 12:59 PM
CJ MEDEVAC
  • 11,004 POSTS
See my profile. Clicking/ no crank sounds like. EITHER. LOW/ BAD BATTERY. OR. LOOSE/ CORRODED CONNECTIONS AT BATTERY OR SOLINOID. Haywire guages/ etc. . Maybe due to LOW BATT/ LOW VOLTAGE
Tighten/clean connections discussed above. Try it. If NO-GO.
Get GOOD+HEAVY/ LONG set of jumper cables, Jump it (may need little charge-up time). If cranks.
Have Someone follow you(w/jumper cables) to Advance Auto or Autozone. Or local store. To check charge system/ Battery Condition. Either they can assist for FREE or direct you to INEXPENSIVE/ REPUTABLE ASSISTANCE. If NEW BATT needed expect $40----$80 BILL usually they install it FREE!
Please UPDATE ME on your catastrophy,
Love, Turddog
Friday, February 26th, 2010 AT 10:15 PM
