2001 Jeep Cherokee noise
82,000 MILES • 6 CYL • 4WD • AUTOMATIC
BURN1985
i hear a rubbing sound from the right front starts around 25 to 30 mph makes the noise for a couple weeks and then quits for a few weeks and starts again for a few weeks any ideas thanks
Mar 19, 2010 at 5:14 PM
JACKEEMAC
  • 7 POSTS
Did you find out what was wrong with your jeep? Mine is making the same noise. I've spent $1200 trying to fix it & can't spend anymore to find the problem. It's driving me crazy...Please post what the problem was if you found it...
Mar 25, 2010 at 9:27 AM
BURN1985
i cant find what the noise is im thinking about turning the rotor and mybe new pad..what di you do on yours that didnt work maybe we compare notes we can find the answer thanks jackeemac
Mar 26, 2010 at 4:38 AM
JACKEEMAC
  • 7 POSTS
I've replaced cv joints, wheel bearing, rotors and brake pads...i've spent a small fortune and still can't figure it out...i was told it could be the transfer case by one guy another moved the the part that goes into the drive shaft and said the chains sounded tight he didn't think it was the transfer case..One said he checked the pulleys and it wasn't the pulleys..Someone told me he had the same problem with a durango & it was the heat shields...The guy that changed my brakes said it didn't have heat shields...the problem i have is i take to friends of mine that work on vehicles..I am a woman thats not dumb to a vehicle my dad owned full service gas stations and he made sure we were not dumb to vehicles but he didn't want his girls to be mechanics so I can't do the work...I can research and try to figure out and sometimes know what noises are what problems...I somewhat think it sounds like the pulley so I'm going to take mine to my ex brother n law this weekend make him give me one of his vehicles to drive and he will find the problem for me..I know he will...As soon as he does I will let you know...It should be sometime over the weekend or the 1st of the week but he will figure it out for me...
IT'S DRIVING ME CRAZY AND BREAKING ME...LOL!
Mar 26, 2010 at 9:33 AM
JACKEEMAC
  • 7 POSTS
I was just told that a hairline crack in the flywheel will make that kind of noise. I haven't tracked down my brother n law yet but if you do your own mechanic work that might be something to check out. He said part isn't expensive labor could be.
Mar 27, 2010 at 5:18 AM
BURN1985
my mechanic thinks my noise is the bearing its getting louder hope it what the noise is like you its starting to cost money lots lol
Mar 27, 2010 at 3:47 PM
