2001 Jeep Cherokee low idle when its cold
107,461 MILES • V8 • AWD • AUTOMATIC
THRORUG
Since the start of winter when I start my Jeep it runs at an extremely low idle and will shut off due to it. I have to drop the auto trans from drive to 2 or 1 when driving thru my neighborhood to keep it running until it is nice and hot and even then sometimes it will drop down to low idles at a stop light usually down to 300-400 rpms. I run 92 octane and have put fuel injector cleaner in it. I can't see the spark plugs to change them since I havent found a manual yet. I think the plugs are inside the heads.
Jan 10, 2008 at 9:15 AM
BLACKOP555
  • 10,386 POSTS
You may want to look into cleaning out your throttle body and also changing your coolant temperature sensor.
Jan 10, 2008 at 9:24 AM
