2001 Jeep Cherokee flasher
2001 JEEP CHEROKEE
137,000 MILES • 6 CYL • 4WD • AUTOMATIC
BOYLES1380
how do i replace the FL27 flasher to get my turn signals workng again
Oct 3, 2010 at 11:31 AM
BLUELIGHTNIN6
  • 16,542 POSTS
The flasher is up inside the dash, above the regular fuses. You will need to remove the lower dash panel to gain access to the flasher.
Remove the lower dash panel and use a flashlight to locate the flasher unit. Check the relay that you have identified by feeling the outside of the casing and turning on the turn signals. You should feel a mechanical clicking inside the flasher if you have chosen the right one.
Replace the bad flasher with the new one. Reinstall the lower dash panel and start the Grand Cherokee. Turn on the turn signals and check to see that the lights work as they should.
Oct 3, 2010 at 12:45 PM
