2001 Jeep Cherokee Error codes for misfireing cylinders
85,000 MILES • 6 CYL • 4WD • AUTOMATIC
RC508ABN
  • 6 POSTS
I have a 2001 Cherokee. I decided to try Zmax and put in the fuel addative. About 20 miles later the check engine light came on. The garage said that A couple of cylinders were misfiring. He then told me that the zmax brakes up junk in the fuel and lines and it gets clogged in the injectors and that some injector cleaner would take care of it. It did but I havent used zmax since and every couple of months the check engine lights comes on and its the same problem with cylinders misfiring. Replaced the fuel filter and still have the same problem. I cant tell by listening to it and it seems to run smooth. I am howerver not gettin as good of milage as i was before. I am also now gettin a "Evaporative Emission Control System Pressure Sensor Low Input" code that comes up. Wish i had taken auto shop back in school istead of woodshop LOL
Jan 23, 2008 at 3:03 AM
2CARPRO JACK
  • 11,533 POSTS
Have you tried a fresh set of spark plugs? Tune up? As far as the evap code, I would need the code # to look it up, dont see what you are describing on the list. Is that a Cherokee Classic,Limited, SE, Sport?
Jan 23, 2008 at 11:56 PM
RC508ABN
  • 6 POSTS
[quote:af3f6b1882="2CarPro Jack"]Have you tried a fresh set of spark plugs? Tune up? As far as the evap code, I would need the code # to look it up, dont see what you are describing on the list. Is that a Cherokee Classic,Limited, SE, Sport?[/quote:af3f6b1882]
The code number was 452 and no I havnt tried a tune up or fresh plugs
Jan 26, 2008 at 1:28 PM
2CARPRO JACK
  • 11,533 POSTS
Dont see a code P0452. All the numbers around it are EVAP codes for leaks large and small. Is the gas cap on it?, is the cap in good condition?
Jan 27, 2008 at 12:53 AM
RC508ABN
  • 6 POSTS
[quote:87d6a3ed46="2CarPro Jack"]Dont see a code P0452. All the numbers around it are EVAP codes for leaks large and small. Is the gas cap on it?, is the cap in good condition?[/quote:87d6a3ed46]
P0452 Evaporative Emission Control System Pressure Sensor Low Input (I cut and pasted the code from this website-2carpros
Yes, the gas cap is on and in good condition.
Jan 27, 2008 at 5:02 AM
2CARPRO JACK
  • 11,533 POSTS
Cherokee Classic,Limited, SE, Sport or Grand Cherokee? Most likely the pressure sensor is bad, need to know the exact production date and model to look up its location
Jan 27, 2008 at 11:27 PM
RC508ABN
  • 6 POSTS
[quote:270c316fa4="2CarPro Jack"]Cherokee Classic,Limited, SE, Sport or Grand Cherokee? Most likely the pressure sensor is bad, need to know the exact production date and model to look up its location[/quote:270c316fa4]
2001 Cherokee sport
Jan 28, 2008 at 2:19 AM
2CARPRO JACK
  • 11,533 POSTS
Still cant find that code or that component on the locator for your year and 1 year either way. Those are generic codes.Where did you get the original code read from?
Jan 28, 2008 at 2:55 AM
RC508ABN
  • 6 POSTS
[quote:82a27eee10="2CarPro Jack"]Still cant find that code or that component on the locator for your year and 1 year either way. Those are generic codes.Where did you get the original code read from?[/quote:82a27eee10]
Hypertech power programmer is what i got the code from. Got it a second time this morning whn the engine lite came on. Its getting a tune up right now as we speak. I will see what the mechs have to say on it.
Jan 28, 2008 at 4:20 AM
2CARPRO JACK
  • 11,533 POSTS
That might not be a manufacturer specific code , generic. See what their scanner says
Jan 28, 2008 at 6:56 AM
