Engine Cooling problem
2001 Jeep Cherokee 6 cyl Four Wheel Drive Automatic
How many pounds of pressure are engine cylinders supposed to have when doing compression test?
Sunday, August 16th, 2009 AT 6:41 PM
SERVICE WRITER
MECHANIC
Compare cylinders compression reading, typical compression readings are between 125 p.s.i. and 160 p.s.i. all cylinder readings should be within about 5% of each other
