2001 Jeep Cherokee cold air
10,600 MILES • 6 CYL • 2WD • AUTOMATIC
SKIPPYSBOAT
only cold air -motor temp gage up,new themostate-no heat when motor warm ? what controls heat ? fuse relay? sensor? panel feels warm under dash..also new radiator? help please? just bought it...
Jan 16, 2009 at 11:26 PM
RAY5796
  • 6 POSTS
I had the same problem with my 2001 Jeep Grand Cherokee. The problem turned out to a broken blend door pin. The blend doors control the cold air [via AC] and hot air [via heater] mixture to provide the selected temperature setting. When the blend door pin breaks, the default position is down which consequently blocks the hot air section. This means your AC works fine, but the heater, at best, will blow ambient [outside] air temperature. The dealership, of course, can fix this problem, but as I'm sure you can imagine, it would be very costly. I purchased a kit online and installed it in my driveway.
Jan 18, 2009 at 7:51 AM
