2001 Jeep Cherokee car shakes at 50 mph
110,000 MILES • 6 CYL • 4WD • AUTOMATIC
ZSUZSA100
My car and steering wheel shakes at 50 mph.
Can you please list what needs to be checked on it and where do I go to do those checks.?
Feb 23, 2009 at 3:57 PM
2CARPRO JACK
  • 11,533 POSTS
Have the front end inspected for bad bushings or rod ends. Also have them check the tires, if anyone has used a liquid tire sealer, it can cause strange vibrations at those speeds from it moving around in the tire.Doubt it is brake issue, then the wheel would saw back and forth when you applied the brakes. Beware of chain stores, they live off the up-sell and could replace the entire front end for a smaller problem.Ask around for referrals for a brake/front end shop that friends/family uses.
Feb 24, 2009 at 12:02 AM
