2001 Jeep Cherokee 4wd engaged indicator lights
69,000 MILES • 6 CYL • 4WD • AUTOMATIC
MACATAK222
My 4wd seems to work both in low and high range but I never get an indicator light on the dash. Does this indicate a mechanical problem or just a burned out bulb?
Jan 5, 2010 at 12:25 PM
  • 110,248 POSTS
Chances are it is just a bulb. However, on the transfer case is a vacuum actuated switch that sends power to the light when the 4wd is engaged.
Jan 9, 2010 at 3:58 PM
