2001 Jeep Cherokee #3 cylinder missfire
2001 JEEP CHEROKEE
LT742
Computer problem
2001 Jeep Cherokee 6 cyl Four Wheel Drive Automatic
could this be lust a bad plug
Dec 10, 2008 at 7:56 AM
Misfire at no.3 check its sparkplug, compression and injector.
Misfire can be caused by worn or fouled spark plugs, a weak spark (weak coil, bad spark plug wire), loss of compression, vacuum leaks, anything that causes an unusually lean fuel mixture (lean misfire), an EGR valve that is stuck open, dirty fuel injectors, low fuel pressure, or even bad fuel.
Dec 10, 2008 at 7:58 AM
