2001 Jeep Cherokee
2001 JEEP CHEROKEE
85,000 MILES • V8 • AWD • AUTOMATIC
TSTUART3S
Slight delay shifting into reverse & drive. Going on a trip soon. Want to have transmission serviced. How much should that cost? Also jiffy lube suggested I get the differential serviced. Is that necessary? How much should that cost?
Jul 22, 2009 at 6:26 AM
  • 110,240 POSTS
A trans service with a new filter and gasket is normally around 100.00 based on where you live. As far as the differential, I believe the manual says 100K unless there is contamination. Have them show you the diff fluid. It should be a golden color. If it is, refer to your owner's manual maintenance schedule to determine if it's due just to make sure.
Jul 26, 2009 at 4:30 PM
