2000 Jeep Cherokee want crank
160,000 MILES • 6 CYL • 2WD • AUTOMATIC
WILMA123
changed battery still want crank motor spins but want start
Mar 24, 2010 at 2:12 AM
JDL
  • 16,098 POSTS
Hi, if your saying, the starter cranks good,but, the vehicle won't start, Have a helper crank it while you visually check for spark at the plugs. If you have spark everywhere, use a gage and check fuel pressure.
To check for spark, you can pull a plug wire, stick known good plug or spark tester in the boot, ground metal part of plug/tester to metal part of engine. Watch for spark, engine cranking.
Some of the national brand autostores used to loan out a fuel pressure gage, if you don't have one. You can call them and ask?
Mar 24, 2010 at 2:22 AM
WILMA123
getting spark getting fuel motor spins carb pops like want to start
Mar 24, 2010 at 2:33 AM
JDL
  • 16,098 POSTS
What was the fuel pressure spec?? The fact that you may have some fuel pressure, isn't good enough. If it is backfiring, it could be a timing issue. I'd want to see, first, if the cam and crank signals are in sync. I'd have to use a scanner that will show a sync signal. Even to check for trouble codes, at the least, You need an obd2 code reader or a scanner that will show live engine data.
Just a thought, if you hold the throttle valve open just a little, will it start?
Mar 24, 2010 at 4:01 AM
