2000 Jeep Cherokee vent system
120,000 MILES • 6 CYL • 4WD • AUTOMATIC
BRYANKE
Hi, I have heat and airconditioning. When I turn the selector switch for floor or vents or defrost, nothing moves. Is there a fuse or a relay out that can fis this problem? THANKS
Nov 25, 2009 at 5:36 AM
  • 110,248 POSTS
IT sounds like you have a vacuum leak. The vent doors are actuated by vacuum. Check under the dash for a leak and follow the source through the firewall to the engine. If you have the engine running, you may hear a hissing sound from the leak.
Let me know what you find.
Nov 27, 2009 at 6:05 PM
