2000 Jeep Cherokee STALLING
140,000 MILES • V8 • FWD • AUTOMATIC
CDTKL2009
HOW TO I DETERMINE IF ITS MY BATTERY OR MY ALTENATOR?
May 5, 2009 at 9:49 AM
BMRFIXIT
  • 19,053 POSTS
Most part stores will do the testing for you
need a volt meter and check battery volts
should be 12.5 v start engine should not drop below 10 V while engine cranking
if not suspect bad battery
after starting, volts should be above 13V less than 15v if not suspect bad alternator or wiring
good luck
need manual CHECK IT @
http://www.2carpros.com/kpages/auto_repair_manuals.htm
May 5, 2009 at 12:55 PM
