Vehicle begins to squeak while driving after warming up. Does not squeak on initial startup or first few minutes of drive. Noticed crankshaft pulley is wobbling.
I've replaced: belt, power steering pump and pulley, idler pulley and pulley that bolts directly to engine.
February 24, 2008
BMRFIXIT,
Thanks for the info.
I wasn't sure what you meant by the pulley being in two pieces but now understand. There is a thin rubber ring on the outer edge of the inner pulley and the inner pulley/rubber ring is inserted into a larger pulley all of which is called the vibration damper. I'll purchase one and install and let you know how it goes.
Thanks.
February 24, 2008
BMRFIXIT,
Thanks.
Feb 21, 2008 at 7:44 PM
