2000 Jeep Cherokee Runs Rough When Started Warm
GUNNERDOGGY
My 2000 Jeep Cherokee usually runs great, however recently when i run it for a while, park it for a few minutes, and then start it again, it runs rough, has low power and will almost stall if i don't give it some gas. After about 20 seconds it dissapears, and it runs great again with no problems. When started cold, it starts and runs fine, the problem only occurs when it is warm. It seems to be happening more often, what could be the problem?
I have relatively new plugs and battery.
2000 Jeep Cherokee
4.0L V6
84K miles
Dec 15, 2006 at 1:40 AM
CARUNDELL
  • 602 POSTS
[quote:667b093eed="gunnerdoggy"]My 2000 Jeep Cherokee usually runs great, however recently when i run it for a while, park it for a few minutes, and then start it again, it runs rough, has low power and will almost stall if i don't give it some gas. After about 20 seconds it dissapears, and it runs great again with no problems. When started cold, it starts and runs fine, the problem only occurs when it is warm. It seems to be happening more often, what could be the problem?
2000 Jeep Cherokee
4.0L V6
84K miles[/quote:667b093eed]
Hey gunner,
At any point do you get a check engine light?
Chris
Dec 15, 2006 at 10:07 PM
GUNNERDOGGY
[quote:ae2eecb9bb="carundell"][quote:ae2eecb9bb="gunnerdoggy"]My 2000 Jeep Cherokee usually runs great, however recently when i run it for a while, park it for a few minutes, and then start it again, it runs rough, has low power and will almost stall if i don't give it some gas. After about 20 seconds it dissapears, and it runs great again with no problems. When started cold, it starts and runs fine, the problem only occurs when it is warm. It seems to be happening more often, what could be the problem?
2000 Jeep Cherokee
4.0L V6
84K miles[/quote:ae2eecb9bb]
Hey gunner,
Chris[/quote:ae2eecb9bb]
Chris,
No check engine light yet.
Thanks,
Justin
Dec 16, 2006 at 11:35 AM
