2000 Jeep Cherokee only passenger side has cold air driver
160,000 MILES • V8 • AWD • AUTOMATIC
SKIMO12345
I have hot air on the driver side and cold air on passenger side. no controll on temperature control. now I dont even have a fan. no air is blown even on high.
Aug 25, 2010 at 10:24 AM
MADMIKE1735
  • 951 POSTS
if its cold on one side and hot on the other, then your blend air door stuck.... as far as blower goes, if it only worked on high, that is your blower motor resistor.... if it stopped working all together, then it finally burned up, check it.
Aug 26, 2010 at 2:58 PM
