HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Jeep
Cherokee
Engine
Oil
Low Pressure
2000 Jeep Cherokee oil pressure drop
XJBOSS
MEMBER
2000 JEEP CHEROKEE
Engine Mechanical problem
2000 Jeep Cherokee 6 cyl Four Wheel Drive Automatic 100k miles
My oil pressure is dropping at idle I know this could be a few things where should I start?
Friday, August 20th, 2010 AT 8:16 PM
MECHANIC
Check the oil pressure with a mechanical gauge, if normal replace the oil pressure switch. If abnormal could mean oil pump and engine bearing.
Friday, August 20th, 2010 AT 8:23 PM
MECHANIC
Check the oil pressure with a mechanical gauge if normal replace the oil pressure switch abnormal could mean oil pump and engine bearings
Friday, August 20th, 2010 AT 8:25 PM
Please
login
or
register
to post a reply.
Related Oil Low Pressure Content
2000 Jeep Cherokee Low Oil Pressure While Driving
Engine Mechanical Problem 2000 Jeep Cherokee V8 Four Wheel Drive 77400 Miles I Was Getting "low Oil Pressure" When Letting Off The Gas...
Asked by
moseby8
2000
JEEP CHEROKEE
GUIDE
Oil Pressure Low
Engine oil is used to cool and lubricate bearing and machined surfaces. Without oil pressure an engine will experience extreme internal engine damage due to heat caused by...
2000 Jeep Cherokee Coolant Loss Low Oil Pressure...
Engine Cooling Problem 2000 Jeep Cherokee 6 Cyl Four Wheel Drive Automatic 70k Miles Looses Coolant. Have To Refill The Resevoir Every...
Asked by
spokediver
1 ANSWER
2000
JEEP CHEROKEE
2000 Jeep Cherokee Oil Pressure-over Heating
Over Heats With A/c On. Has No Oil Pressure After Warm Up, And Motor Is Very Hot.
Asked by
bobbyla
1 ANSWER
2000
JEEP CHEROKEE
1993 Jeep Cherokee Oil Pressure Drops
My Cherokee Shows Excellent Oil Pressure. But After A 30 Mile Trip On The Highway. The Oil Pressure Drops To Near Nil At Idle? Either A...
Asked by
Gudtime
1993
JEEP CHEROKEE
1994 Jeep Cherokee Low Oil Pressure
Hi Guys. Ok I Am A Mechanic Myself But Seem To Be Stumped On This One. My Inline 6 4.0l Was Having Low Oil Pressure And Bearing Noise. I...
Asked by
jamieleegauthier
1994
JEEP CHEROKEE
VIEW MORE
