2000 Jeep Cherokee Need help with problem
98,000 MILES • 6 CYL • 2WD • AUTOMATIC
SILKJAMIES
The cooling fan will not go off even after the engine is turned off. HELP
Dec 6, 2009 at 11:11 AM
BLACKOP555
  • 10,386 POSTS
it shoudl run for a little bit after engine is off. does it turn off eventually or no? take off the cooling fan relay and measure on the inlet power from the coolign switch and see if your getting voltage if you are the switch could be bad. if nothing and the relay when pulled kills the fan then the relay is sticking.
Dec 6, 2009 at 12:23 PM
