front brake caliper bracket
160,000 MILES • 6 CYL • 4WD • AUTOMATIC
MDSJEEP
I am having a very difficult time removing the two bolts holding the caliper bracket on. They are seized from rust ect... I assume they are standard threads and I belive they are 18mm. Any suggestions/advice
Jan 3, 2009 at 2:56 AM
  • 110,248 POSTS
Have you tried using a penatrating oil? Allow the bolts to soak over night, tap them with a hammar to jar them and then try.
I believe you can try heating the steering knuckle too. Steel expands when it gets hot and may help loosten the bolts. Once you get them out, make sure the threads in the steering knuckle are good and safe to reuse.
May 20, 2021 at 3:06 AM
