hi, i have a 2000 jeep grand cherokee limited 4.7L with 180k on it and just yesterday as i was driving back from the ball drop it stauled on me rite when i hit 40mph so i pulled over and tried to start it up again a few times n i get nothin. So i jus towed back to my house n started it up again the next morning n it started up but with a loud knockin sound in engine n hard shakin, i dnt knw what the problem is but i checked my oil n it was dryed out even tho i jus did an oil change less than 1200 miles ago?? so i put more oil to see what happens n still nothn changed! some say my engine is blowin n one guy said it may be my timing shaft? i jus dnt knw... but if it is im willin to replace the motor but i also wana knw if a 5.7L motor can replace it with no other work done? because i found a used one for $400.00 which is around the same price range for the 4.7L??? thank you
Jan 2, 2010 at 1:24 AM
