2000 Jeep Cherokee engine dies
120,000 MILES • V8 • 4WD • AUTOMATIC
CLEANIT
When the engine is warm and turning a cornor the engine dies.
When I try to start the engine again, it wont until we sit for 10 or 15 minutes.
when the key is turned on to start again all the guages start up but the fuel guage. it acts as though there is not fuel.
I have had mechanices check and many sensors changed but it still does it .
another mechanic sujested the fuel pump? another some transmission sensor?
Aug 21, 2009 at 3:12 AM
  • 110,251 POSTS
It could be a fuel pump. WHat you need to do is check fuel pump pressure when it happens. Here is a how to for that:
http://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
Also, has the check engine light come on?
Aug 24, 2009 at 2:43 PM
CLEANIT
no, light has not come on.
there is no engine problem code shown.
I have decided to change fuel pump and filter.
will let you know
Aug 25, 2009 at 6:02 AM
  • 110,251 POSTS
Before going to that expense and work, have you checked pressure? Here is the how to for checking:
Do this before replacing to make sure it is a problem.
Let me know what you find.
Aug 25, 2009 at 7:26 AM
