2000 Jeep Cherokee door locks
123,000 MILES • V8 • 2WD • AUTOMATIC
DON STACY
2000 jeep grand cherokee laredo-- rear door will not unlock . slide switch will not move in either direction, electric switch will not activate .. Removed door pannel to gain as much access as possible. Actuating rod for slide switch frozen --will not move in either direction. If I could get door open ---if-if-if --maybe a new actuator would fix the problem . Your opinion please.
May 4, 2009 at 6:47 AM
  • 110,248 POSTS
You need to disconnect the actuator so you can manually unlock the door.
May 17, 2009 at 12:45 PM
