2000 Jeep Cherokee compressor pulley rattle
MRDONOTHING
Hey guys im new with this forum and hope i can get help over here--- i have a 2000 Jeep cherokee 4wd 6cyl 4.0 liter engine and i noticed a rattle and straining on the engine a couple days ago but made nothing of it, a few days later it got worse and i stopped driving it and opened the hood to see the compressor pulley shaking and not running smoothly so im assuming the bearings are shot on the pulley, so i then tried the a/c and it kicked on for a second and shut off, it did that twice and im not sure if the a/c works anymore because of the compressor failing or perhaps because the pully is shot and not running smoothly and causing it to fail, i dont know much about compressors so im not sure how it works,now my questions are as followes, can i change just the pulley?, do i change the compressor? is it difficult?
if anyone can help me i would really appreciate it very much
Thank you
Ike
Nov 10, 2007 at 10:31 AM
SINGLESIX
So far, it's been impossible to find a replacement pulley assembly for my 2000 Jeep Cherokee with a bad a/c pulley bearing. Your best bet is to pull the pulley off the pump and either get the bearing out yourself or have it removed by someone. Give Buffalo Bearings a call (1800-669-8019 (716) 874-1720 Fax (716) 874-3063) and tell them what bearing you have. I had mine the next day. Press things back together and your in business. All for about $32.00.
Dec 7, 2007 at 6:09 AM
