2000 Jeep Cherokee
NESS.VAN
  • 2000 JEEP CHEROKEE
  • 4 CYL
  • 140,000 MILES
Sputters and jerks lights dim but stay on then engine quits. If I leave it alone for while it will start but after a minute or so will eventually quit. Fuel pump or electrical problem?
Friday, January 1st, 2010 AT 1:21 AM
Check the battery and alternator if okay and next time do below immediately don't wait for nothing to catch the cause:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Friday, January 1st, 2010 AT 5:16 AM
