1999 Jeep Cherokee Vehicle shakes extremly bad after 70 mph
1999 JEEP CHEROKEE
188,000 MILES • 6 CYL • 2WD • AUTOMATIC
CHEFPDUN
After having lite maintenance done ( fuel injectors cleaned, new seal for front rack and pinion differential , new rotors and brakes on front, and a 4 wheel alignment. The results are extreme shaking after 70 mph. It shakes enough to spill a full glass of water. It scared the living HELL out of me.
I then return to the shop, to have them to try, to make me think the've balanced the tires. They took the tires off, took them inside the shop. Then they supposedly rotated the tires. NO balancing was involve at all.
My truck had just a little shake before. It shakes way worst than before I had the work done. WHAT can it be. HELP!!!!!!!!!!
Apr 28, 2008 at 3:21 PM
  • 31,937 POSTS
Hi there,
is the steering wheel shaking as well? if so more than likely it is a front wheel? steering issue, if the steering is stable but the car shakes, i would be looking at a rear wheel ?drive line problem. you must remember that balance and alignment machines are only any good if kept up to calibration and the operator is component. keep this in mind.
mark Mhpautos)
Apr 28, 2008 at 10:13 PM
