1999 Jeep Cherokee vacuum leak
1999 JEEP CHEROKEE
JJURBERGS
Brakes problem
1999 Jeep Cherokee 6 cyl Four Wheel Drive Automatic
When I release the brake pedal I hear a vacuum leak for several seconds. Then it seems to fade away until the next time that I brake and release the pedal. What is the problem?
Dec 17, 2009 at 9:55 AM
  • 31,937 POSTS
Hi there,
Your brake booster has failed, this will need to be replaced or repaired, if it totally fails you will have a very heavy and inefficient brake pedal, get this looked at ASAP.
mark (mhpautos)
Dec 17, 2009 at 10:17 AM
