1999 Jeep Cherokee Tie Rods
190,000 MILES • 6 CYL • 4WD • AUTOMATIC
IRISHJAYHAWK
My Jeep has a vibration when it gets up to 52 to 55 mph. Could it be the Tie rods
Jul 23, 2009 at 8:28 AM
  • 110,248 POSTS
Do you feel the vibration in the steering or the seat or both? It could be tire balance, alignment, a bad belt in a tire, bent rim, bad u-joint... and the list goes on.
Let me know where you feel the vibration most, steering or seat.
Jul 26, 2009 at 4:10 PM
IRISHJAYHAWK
I feel it in the steering wheel
Jul 27, 2009 at 12:19 AM
  • 110,248 POSTS
The cheapest thing to try first, is to rotate the tires. If it is tire balance and you put them in the rear of the vehicle, you will feel the vibration chance from the steering wheel to the floor / seat. If it isn't tire balance, then we need to consider a bent rim, a bad tire with a shifted belt, alignment...
LEt me know if it changes.
Jul 28, 2009 at 4:23 PM
