1999 Jeep Cherokee starting engine
DEBBIE COGDILL
  • 1999 JEEP CHEROKEE
  • 6 CYL
  • 4WD
  • 179,000 MILES
Car started ok and when went to back out of parking space it died as if someone turned off the engine. Tried to restart it and it will crank but not fire over
Wednesday, March 3rd, 2010 AT 12:32 AM
Cranks but no start condition:
Fuel and Spark:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Wednesday, March 3rd, 2010 AT 12:45 AM
