1999 Jeep Cherokee Pick up coil
1999 JEEP CHEROKEE
120,000 MILES • 6 CYL • 4WD • AUTOMATIC
MRCROWBAR
I'm posting for an older friend who doesn't have a computer... He's stuck on getting his daughters Jeep to keep running...
He wants to know if a Pickup Coil (?) has anything to do with fuel pressure? He's changed the fuel pump/filter, but the truck just keeps stalling after running for a few minutes, and can't figure out what is going on with it.
Does anyone have any suggestions to why it's not getting fuel after a few minutes of run time?
Thanks in advance!
Shawn
Feb 17, 2009 at 1:56 AM
CRZYDRVR
  • 432 POSTS
A good thing to check out are the crankshaft positioning and camshaft sensor (under the distributer cap) are in spec. And check to see if they are putting out any signal. If they do not put out signal and run together vehicle will have issues starting and running.
Feb 17, 2009 at 12:29 PM
