1999 Jeep Cherokee Oil pressure
155,000 MILES • 6 CYL • 2WD • AUTOMATIC
JUSTEMPTYEVERYPOCKET
I own a 1999 Jeep Grand Cherokee, recently while driving my "check guages" light came on. I noticed that the oil pressure dropped when I either slowed down or stopped. While driving the guage read around 45 psi but when I stopped it dropped to around 10 psi. After making it home I let the Jeep cool down and went to crank it again, no problems at all, no drop in pressure. The next day the same thing happened. Any suggestions on a cure for this?
Dec 23, 2007 at 4:46 AM
  • 75,988 POSTS
Get an engine flush and then check the actual oil pressure with a mechanical oil gauge if its normal test the oil pressure sending unit.
Dec 23, 2007 at 4:52 AM
