1999 Jeep Cherokee front speakers
96,000 MILES • 6 CYL • 4WD • AUTOMATIC
RYANK1014
the front speakers dont play at all i put new ones in but still nothing. there is some power going to the wires but even with new speakers nothing plays.
Jan 12, 2008 at 8:13 AM
LAVA229
I have a 2001 Jeep Cherokee. I had the same problem with both speakers in the front doors.
Inside the protective rubber sleeve to protect the wires from the chassis to door, you will find a splice that is stiff. Because of the bending of these wires everytime the door is opened and closed, the protective covering over the splice weakens and breaks.
Solution: Slice the rubber sleeve down it's long axis, remove the sleeve. Find Black/Green Wire (check this color code to be sure) to splice. Cut and strip back wires and repair accordingly. Slide boot sleeve back over wires.
Good Luck
Michael
Mar 26, 2008 at 4:44 PM
