1999 Jeep Cherokee engine change wow
125,000 MILES • V8 • 2WD • AUTOMATIC
DAVIDFAULK
1999 Jeep Grand Cherokee 4.7 engine went bad. I replaced with 2002 dodge durango 4.7. changed wiring harness and all sensors to be sure was safe because of computer.engine acts as if out of time. i have found out that the 2002 Durango carries a different tooth gear on crankshaft for the crank sensor than the 99 Cherokee, but that a 2000 and 2001 grand Cherokee carries same tooth so can I use a 2000-2001 grand Cherokee comp and resolve the problem?
Mar 20, 2008 at 12:46 PM
SERVICE WRITER
  • 9,123 POSTS
Hopefully someone can answser this. with this kind of changes you have a :
https://images.2carpros.com/forum/automotive_pictures/30961_frankenstein_9.jpg
The unknowns are scary until you hit them.
Mar 20, 2008 at 1:04 PM
BMRFIXIT
  • 19,053 POSTS
I wouldn't go this route
flashing reprogramming
and not the same
Mar 20, 2008 at 1:08 PM
