1999 Jeep Cherokee engine change wow
DAVIDFAULK
  • 1999 JEEP CHEROKEE
  • V8
  • 125,000 MILES
1999 Jeep Grand Cherokee 4.7 engine went bad. I replaced with 2002 dodge durango 4.7. Changed wiring harness and all sensors to be sure was safe because of computer. Engine acts as if out of time. I have found out that the 2002 Durango carries a different tooth gear on crankshaft for the crank sensor than the 99 Cherokee, but that a 2000 and 2001 grand Cherokee carries same tooth so can I use a 2000-2001 grand Cherokee comp and resolve the problem?
Thursday, March 20th, 2008 AT 7:46 PM
SERVICE WRITER
  • 9,123 POSTS
Hopefully someone can answser this. with this kind of changes you have a :
https://www.2carpros.com/forum/automotive_pictures/30961_frankenstein_9.jpg
The unknowns are scary until you hit them.
Thursday, March 20th, 2008 AT 8:04 PM
BMRFIXIT
  • 19,053 POSTS
I wouldn't go this route
flashing reprogramming
and not the same
Thursday, March 20th, 2008 AT 8:08 PM
