1999 Jeep Cherokee Blower
1999 JEEP CHEROKEE
147,000 MILES • 6 CYL • 4WD • AUTOMATIC
KKILBOURN
This blower only runs on low speed. Occasionally while driving if the switch is set on 4 the blower will begin to blow hard and then go back to low speed.
The vaccum switch appears to work because I can change from floor to upper vents to defrost, as well as hot to cold,but can never get the blower to blow on high speed . I took the climate control out of the dash and took it apart. It appears that one connction has taken some heat so i decided to try replacing it. I bought one at salvage and replaced the climate control and nothing has changed. Im not sure now if im getting anything even at low speed . I checked the fuse for the blower and it is good. I'm not sure what to try next. FYI the air conditioning on this has never worked either.
Oct 22, 2008 at 8:15 PM
