1999 Jeep Cherokee belt squeal
100,000 MILES • 6 CYL • 4WD • AUTOMATIC
ROBROUSS1
when the a/c compresser comes on, the belt squeals. I put new belt on, and adj tension. If the a/c system were low on pag oil, could it cause the compresser to drag enough to make the belt squeak.
Apr 21, 2009 at 10:42 AM
  • 110,248 POSTS
I suggest trying to tighten the belt a little more. If the compressor is locking up, you will see smoke coming from the belt on the AC pulley.
Apr 21, 2009 at 1:04 PM
