HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Jeep
Cherokee
Exterior Light
Headlight
1999 Jeep Cherokee
BEAU TALLEY
MEMBER
1999 JEEP CHEROKEE
6 CYL
4WD
AUTOMATIC
200,000 MILES
How much does it cost to repair a headlight?
Monday, December 17th, 2007 AT 1:17 AM
MCQUE
MEMBER
All depends on what is wrong with it. If its just the bulb/lamp assembly.I would guess about $30 tops for the part and another $30 for labor.
If you have an electrical problem, it could run a couple hundred easy, depending on the severity
SPONSORED LINKS
Monday, December 17th, 2007 AT 9:57 PM
Please
login
or
register
to post a reply.
Related Headlight Content
1999 Jeep Cherokee Head Lights
I Am Trying To Put In The Head Lights And Cant Figure Out How To Put It Back. Where Does The Spring Go On The Headlight.
Asked by
MDOUGLAS
1999
JEEP CHEROKEE
VIDEO
Headlight Lens Replacement
Instructional repair video
GUIDE
Headlight Bulb Replacement
The headlight bulb is located inside a water tight headlight lens connected to the wiring harness using a weather tight electrical plug to help repel damage causing moisture...
1994 Jeep Cherokee Dash Lights/head Lights
When Turn On Head Lights, I Loose Dadh Lights
Asked by
tammyg
1 ANSWER
1994
JEEP CHEROKEE
1994 Jeep Cherokee Head Lights Go Off And On
My Daughter Has A Problem Of Headlights Going Off And On After Driving On Bumpy Roads. She Said The Come Back On After She Hit The Dash. Any...
Asked by
satjoe
1 ANSWER
1994
JEEP CHEROKEE
1997 Jeep Cherokee Headlights
Electrical Problem 1997 Jeep Cherokee Last Night, I Tried To Turn My Lights On. The Two Turn Signal Lights And The Brights Light...
Asked by
Cantrell35
1997
JEEP CHEROKEE
1994 Jeep Cherokee High Beans
Electrical Problem 1994 Jeep Cherokee 6 Cyl Two Wheel Drive Automatic The Shaft/lever That Comes Out Of The Side Of The Steering...
Asked by
eugenebr
1994
JEEP CHEROKEE
VIEW MORE
SPONSORED LINKS
Dim Headlights Lights - Tesla Only
How to Replace Headlight Bulb Ford F-150
Online car repair manuals
