1999 Jeep Cherokee
KATHIOWEN1
  • 1999 JEEP CHEROKEE
  • 6 CYL
  • 4WD
  • 176,000 MILES
What can the problem be if my jeep doesnt start, it just clicks. The battery is fine and we just replaced the starter. Not the problem! Please, what can the problem be?
Tuesday, May 25th, 2010 AT 9:13 PM
  • 31,937 POSTS
Hi there,
If the starter is clicking and not engaging you will have to check the main cable voltage, check for 12V check all connections, they may look OK but can be a poor connection, if cable is OK, with a jumper cable bridge out the main battery lead at the starter and the solenoid terminal, if it cranks check starter circuit, if no crank, or just a click it will be a faulty starter.
Mark (mhpautos)
Tuesday, May 25th, 2010 AT 10:32 PM
