1999-1/2 Jeep Cherokee trans. leak
SGEER
On a 1999-1/2Jeep Cherokee Lardo ,where would fluid be going if it's not leaking out of tran.? Owner is replacing between 1 to 2 qt. per. month and states there is nothing dropping on his floor at anytime.
Please, advise as to where you think it maybe going?
Feb 21, 2006 at 4:55 AM
JPAM
  • 307 POSTS
[color=red:3374fc7abd]using 1 to 2 quarts a month there is a good chance that the leaking is happening more going down the road than sitting still. Of course there probally should be some drops here and there were he parks but just might not notice it.. Check the undercarage for the fluid. should beable tofind some sign of the magical fluid.. Because when it comes to transmission fluid there isnt many places it can go, meaning there should be no way for trans. to mix with any other fluid. Thats just the way its setup... Nothing else call 911 and tell them u got a thief.... Jess S.[/color:3374fc7abd]
Feb 21, 2006 at 5:47 PM
Suggested Repair
Inspect the undercarriage for transmission fluid, including leaks that may occur while driving rather than when parked. Small drips at parking spots can be easy to miss. Transmission fluid should not mix with other vehicle fluids, so look for an external leak path.
Conversation Summary
The owner of a 1999 Jeep Cherokee reports adding 1 to 2 quarts of transmission fluid per month with no visible drips on the floor and asks where the fluid is going. The expert says the leak is more likely while driving than when parked, recommends checking the undercarriage for fluid, and notes that transmission fluid should not mix with other fluids.
