1998 Jeep Cherokee wiper switch
1998 JEEP CHEROKEE
TIMPATRICK
Electrical problem
1998 Jeep Cherokee 6 cyl Four Wheel Drive Automatic
how do I replace the rear wiper/washer switch on the dash?
Aug 7, 2009 at 8:17 PM
BMRFIXIT
  • CAR REPAIR CONTRIBUTOR
  • 19,053 POSTS
REAR WIPER SWITCH R & I
Removal & Installation
Rear wiper switch is located in accessory switch bezel, located below A/C-heater control panel. Disconnect negative battery cable. Using a trim stick, gently pry around perimeter of instrument panel center bezel and remove bezel. Remove accessory switch bezel retaining screws.
Pull accessory switch bezel out far enough to access wiring harness connectors. Disconnect connectors. Remove accessory switch bezel. Using a thin bladed screwdriver, remove rear wiper switch from accessory switch bezel.
To install, reverse removal procedure. When installing rear wiper switch, ensure both switch snap retainers are fully engaged in accessory switch bezel.
Aug 7, 2009 at 10:28 PM
