HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Jeep
Cherokee
Engine
Symptoms
Not Running
1998 Jeep Cherokee WILL NOT START
NEKEI
MEMBER
1998 JEEP CHEROKEE
6 CYL
4WD
AUTOMATIC
123,000 MILES
JEEP RAN OUT OF GAS AND OVER HEATED TRYED TO START IT WILL TRY BUT WILL NOT TERN OVERWHAT SHOULD I TRY?
Thursday, January 10th, 2008 AT 11:44 AM
BMRFIXIT
MECHANIC
Check fuel pressure
do a head gasket test
SPONSORED LINKS
Friday, January 11th, 2008 AT 9:04 PM
Please
login
or
register
to post a reply.
Related Engine Not Running Content
Won't Start!!
It Always Ran Perfectly Fine And I Haven't Had Problems With It Except For An Issue With A Poor Connecting Battery Cable (since Resolved...
Asked by
DarthMedicus
1998
JEEP CHEROKEE
VIDEO
How to fix an engine that wont start
Instructional repair video
GUIDE
Engine Not Starting
Over the past 20 years at 2CarPros we have identified the top problems that are easily fixed. This guide can save you a trip to the repair garage or calling a tow truck and...
Will Not Start. Not Getting Fire From Coil?
Will Not Start. Not Getting Fire From Coil. Put New Coil On. Has 4.0 Motor 155000 Miles, 4 Wheel Drive Automatic. Also It's Not Getting...
Asked by
larry wilson
1 ANSWER
1 IMAGE
1998
JEEP CHEROKEE
1998 Jeep Cherokee Crank No Start
Bought Jeep With Blown Head Gasket, Replaced Head Gasket. Got Everything Hooked Up Like Should Be, Running Header Right Now. Go To...
Asked by
Skittlema94
1998
JEEP CHEROKEE
1998 Jeep Cherokee Crank But Will Not Run
Hello, I Have A 1998 Jeep Cherokee With A 4.0l And 6 Cylinder In Line.A Year Ago It Started To Not Run When The Key Was Turn On For First...
Asked by
silron
1998
JEEP CHEROKEE
1998 Jeep Cherokee 1998 Jeep Grand Cherokee - Will...
Electrical Problem 1998 Jeep Cherokee 6 Cyl Four Wheel Drive Automatic Replaced My Engine With An Engine From A 1996 Same Make And...
Asked by
ajgoodman
1 ANSWER
1998
JEEP CHEROKEE
VIEW MORE
SPONSORED LINKS
Crankshaft Sensor Symptoms
Crankshaft Sensor Replacement
Online car repair manuals
