1998 Jeep Cherokee Will not idle until engine warms up
146,000 MILES • 6 CYL • 4WD • AUTOMATIC
TOLEDOMAN
Just purchased the 98 Jeep. It will start but will not idle on its own. I must feather the gas until the engine starts warming up.
Will then idle & run normally. Does not miss or run badly, just goes to 0 RPM's when it sits overnight and I first try to start it. Restarts ok but wont run normally until arm.
Could this be a TPS? I've heard talk of ASD's doing this too but I'm just guessing.
Any thoughts will be appreciated!
Nov 30, 2008 at 12:40 PM
HAYDAVE7
It sounds like an automatic choke is stuck in the OPEN position.
It has to WARM UP to meet the conditions of a good run in the STUCK OPEN ( OR HOT ) position.
Whether this is purely a thermal choke or is electronic or electrically driven, I do not know.
It may be as simple as a transducer failure or corrosion.
Apparently an AUTOMATIC FEATURE of choke regulation has failed.
dave :'>
Dec 1, 2008 at 2:20 PM
