1998 Jeep Cherokee water on passenger
EZZYPIKINZ
  • 1998 JEEP CHEROKEE
Air Conditioning problem
1998 Jeep Cherokee 6 cyl Two Wheel Drive Automatic
I have water leaking in on the passenger side
when I run the A/C. Any ideas I'm thinking
the drain hose has got disconected maybe.
Saturday, May 9th, 2009 AT 9:40 PM
MIKE H R
  • 3,094 POSTS
Under the hood below the heater motor there should be the drain hose it should be on with a clamp. If not off loosen the clamp and remove. If excess water does not come out then clean it out then check the hose to see if clogged and rinse out then reinstall.
Saturday, May 9th, 2009 AT 9:47 PM
