1998 Jeep Cherokee Timing the engine
170,000 MILES • 6 CYL • 4WD • AUTOMATIC
PINTZ5
I'm replacing the engine in my 1998 jeep cherokee with a used engine. How do u time the engine to work right?
Jan 30, 2010 at 3:58 AM
DOCFIXIT
  • 18,828 POSTS
Timing is not adjustable controled by PCM. Did you install an 98 engine? Use old ingition , manifold and injectors? Has distributor been moved?
Jan 30, 2010 at 4:09 AM
