1998 Jeep Cherokee Starting
1998 JEEP CHEROKEE
147,000 MILES • 6 CYL • 4WD • AUTOMATIC
JGIESTING
less than a year ago i replaced my fuel pump and fuel pump relay and still to this day lose pressure n my tank and it takes two cranks to start. the first crank lasting on average 7 sec. and the second crank being normal. sidenote is when i get gas it starts up like brand new when i leave the gas station. im hoping that my starter wont go out due to the excessive work.
Nov 3, 2009 at 12:43 AM
JEEPFAN
  • 135 POSTS
you may have a bad fuel pressure regulator thats allowing the pressure to bleed down either that or a bad check valve on the fuel pump
Nov 3, 2009 at 12:48 PM
